westend
Apr 06, 2017Explorer
Tin-bender wrote:westend wrote:
Anyone still on the fence about silicone or wishing to find out how it performs can do a simple experiment. Gun a bead of silicone onto a piece of metal and put it in the backyard or next to where you park your RV. Leave it in the weather for two years and report back your findings.
Silicone is an excellent sealant when in compression between two surfaces and not exposed to UV. Left exposed, not so much. The Geocel polymer sealants (Proflex being one) are far superior to silicone on an RV.
Couldn't agree more.
I have used Silicone in the Sheet Metal Industry since it was introduced into common usage (circa 1970?)
And once you put Silicone on a surface you are screwed for ever trying to get anything else to seal it.
As stated it makes a great gasket but is terrible as a skim over sealant.
Just my opinion
Tinbender
My thoughts too. I work in the Construction Biz and since I've found Geocel, I use it almost exclusively for sealing doors and windows.
44,066 PostsLatest Activity: May 13, 2026
