LAJMINNIEPLUS
Dec 03, 2017Explorer
LMMNOCATS_EFI wrote:
So I’ve found the issue , the keys that were in the truck ones put in after the leveling keys were removed were stock but used and had to have been worn as some of you posted hardly “it’s just the way they sit just as the brand new ones on the lots” couldn’t be further from the truth. So if you have one that’s leaning I would start by ordering set on stock keys from GM parts direct think they were 29 bucks and I replaced the bump stop as well cuz I was down there .... swapped out the keys and stops and reloaded the bolts and the truck couldn’t sit more level and the bolts are at even turns so this is the cheapest way to trouble shoot it if you run into or for if you that said there’s was leaning try. Changing out the keys and go from there good luck and thanks for the responses
Any pictures that you could share? My truck is still under warranty. Probably should be covered?
