Major Dad wrote:
Highway 4x4 wrote:
I found that heat was a big problem back there for the pups. It's hard to get AC back there when it's hot. I would have a remote temp gauge back there. If your dogs get stressed and hot, you've got a big problem. The noise level is also high. I have a Bed-rug in mine. You should have gotten a Megga-cab.
I have the megacab and two large dogs. ONE St Bernard may fit back there with the seats folded down, but not two. I'm thinking for giant dogs maybe a 3/4-1 ton van may be the answer, with rear seats removed. The cap on the pickup truck would be a factor in hot weather since the OP lives in West Texas.
If you take out the back seat you may be able to build a platform out of plywood. On my Ford crew the platform was 58"wide by 45"deep and has enough room for 3 Collies. Your megacab would be even larger. You could measure and cut cardboard the same size and lay it on the ground and have your 2 dogs lay on it to see if it would give you enough room. If not you won't have to change your truck.
I thought of a 1 ton d-max van but it was De-rated on power with a lighter duty transmission. This would limit you to a TT as well.
I wrapped the back seat in plastic and store it in the garage. Would take about 15 minutes to put back in.
