Eyetattoo's avatar
Eyetattoo
Dome light problem
Ok so this morning I started swapping out my lights to LED and one of my fixtures now doesnt work. At first I thought it was a problem with the LEDs but when I put the old bulbs back in they wont work either. I checked the fuses and all checked out fine.......Any ideas of how to get it working again? Thanks.
Here is a picture of the type of dome lights I have, the bulbs are 921's:
  • popeyemth wrote:
    LEDs are polarity sensitive .
    Check that the fixture wiring is not reversed-the old bulbs don't care but the LEDs do
    Good Luck, Mike
    I did turn them both ways and neither worked, even the original bulbs now wont work either.....
  • AirForceAngler wrote:
    You did check the switch on the actual light itself, right? Not trying to be a smarta$$, but easily missed.
    Haha I did check that....after I switched the bulbs several times!
  • Turn the led lights the other way..
    My lights from eBay have to be in a certain way.
  • LEDs are polarity sensitive .
    Good Luck, Mike
  • If the fixture is last in line and no power to it, check the next one back for a dropped wire that supplies either ground or power to the dead fixture.
  • while true a voltmeter would be handy you have already popped in a few different bulbs and it doesn't work.
    Without a meter I would pull the light down and inspect the wiring to the fixture to make sure nothing is loose. Maybe also check your bulbs in a working fixture to make sure that they still work.
  • You did check the switch on the actual light itself, right? Not trying to be a smarta$$, but easily missed.
  • I guess I need to go pick up a volt meter to see if I am still getting power there (any suggestions?). Its one of three light fixtures on the main switch and the other two work so Im at a loss.
    Oh and I fixed the picture too.
  • No picture visible.
    try voltmeter in sockets if no power then Take the fixture down.
    Undo fixture from wiring and use a volt meter on the wires.
    If you have voltage;
    then make sure connection was good.
    Retry Volt meter in socket. No power replace socket.
    If you have no power at wiring then check fuse.
