I have a newer 2020 domestic A/C, which runs fine. However, the last couple times camping trips, it seems to not start up correctly once in a while. Usually, it runs fine cycling on and off as normal....
It has happened a 2 different campgrounds. I have a surge/fault protector, and it shows no issues with the campground power.
The a/c seems to operate fine. At night when it is cooler, it cycles with no problem. The issue always seems to start in the late morning as the temps outside start heating up. It just seems like the a/c is being told to start. It is not an issue that the a/c is trying to start but doesn’t.
