Thank you for the suggestions. Please keep them coming. If it would help, the fridge is a Dometic CRX 110. I don't believe there is a fan that sends cold air to the fridge area via a duct system. The unit is fairly well sealed with the only access being to the compressor, fan and related components at the top rear of the unit. I've made sure the fan/condenser area is clean. I'm guessing the cold/heat transfer to the fridge box occurs through radiation from the evaporator. I can't figure out where the evaporator is but once again guessing the majority of it surrounds the freezer box with a portion dropping down behind the plastic cabinet in the fridge. Could there be some type of blockage in the evaporator that prevents the refrigerant to access the fridge area? Id so, is there a remedy? Thanks
