DiskDoctr wrote:
The probe position is adjustable just on the metal fin, which you can see the small distance for the full range of temps.
Hanging down, the probe is an extreme distance away from its intended position.
That being said, you almost certainly found your problem. Let the fridge stabilize a few hours, take the temp, then move the clip+probe up or down a very small amount and wait a few hours to check it again.
Continue this process until you have the desired temps in the fridge. Use a thermometer ;)
Thank you.
Is it OK if I use the BEER thermometer?:)
