Camper_Jeff___K
Mar 13, 2021Navigator
toddb wrote:Camper_Jeff_&_Kelli wrote:
I plan to replace the old screws with stainless if I can find them. I see some people were told by the service department to drill new holes because the lineup wasn't good, couldn't be found. Hopefully, this will be the last time I ever have to mess with it.
I had to do it twice, in a truck camper is about as tight as it gets. First compressor unit failed on startup. Using dowels allowed it to line right up. Good luck!
Compressor failed on startup? That's not very reassuring. Did you let the fridge sit a few hours to let the lubricant and coolant settle down after all the handling during Installation or did instructions mention anything about it. I will check instructions but currently plan to let the system settle 24 hours.
