Camper_Jeff___K's avatar
Mar 12, 2021
Dometic RM2652 version 605A Fridge Rebuild
Ordered a new Amish Built cooling unit for our Dometic fridge today. Should be delivered in a couple days. $748.00 with UPS. I decided on new rather than rebuilt. Looking forward to getting back out and going places again. Got to say, I was surprised at how cheap the fridge is built. A 2" styrofoam box box held together by aluminium backed rubber adhesive. It works just pricey for what it is. I'll let y'all know how it fits back in and performs when done.
The new 120 volt heating element arrived.
  • toddb wrote:
    When you put the new one in use long set screws or cut the heads off some 10-32s (can’t recall the screw size). Put a couple in the freezer cold plate then drop it in, it’ll align easily. That’s the hardest part of the job.
    I plan to replace the old screws with stainless if I can find them. I see some people were told by the service department to drill new holes because the lineup wasn't good, couldn't be found. Hopefully, this will be the last time I ever have to mess with it.
  • When you put the new one in use long set screws or cut the heads off some 10-32s (can’t recall the screw size). Put a couple in the freezer cold plate then drop it in, it’ll align easily. That’s the hardest part of the job.
  • MitchF150 wrote:
    Looking forward to the U-tube vid when you do it! Mitch
    Let me tell you, I have to cut back some of the more descriptive technical terms used during the removal process while recording. Hopefully the install process will go smoother.
    We're excited to get things working again. Planning to make my first trip to the Long Beach Peninsula.
