LarryJM
Nov 16, 2014Explorer II
spoon059 wrote:Road Phantom wrote:
Not the same comparison (Spoon). Your little 22 is much lighter. As I said, my half ton towed my 22 with ease. Try your Tundra hitched to a 29 ft 7500 gross weight trailer and then tell me how good it tows.
How much does my 22 footer weigh? You have no idea. It weighs about 7300 loaded. I've towed an equal weight 26 footer as well, no problems. Again, I would argue that an incompetent driver or setup is the issue here, not an inadequate truck.
I won't make the same (wrong) assumptions you did... I'll let you decide if the driver or the setup was incompetent...
Hmmmm your trailer seems to have magically gained over 800 lbs so could you please post your latest CAT scale weights for your TV/TT combo by axle. When I see "about weighs" IMO screams WAG and as such are fairly meaningless at least to me.
Larry
