stickdog wrote:
I can open the slide window and move the hand bar if necessary. As far as fire if you a$$ is too big for the emergency window I suggest one of the number of diet plans on the tube. I would also consider campgrounds without a bunch of punks running around. I have also run the odds of a punk closing the hand bar assist and a fire breaking out in your RV it's about the same as a meteor crashing through your RV while your sitting on the head taking care of business. A non issue.
Having a bad day? In many RVs, the issue with emergency windows isn't that the owner's a$$ is too big, it's because the window is placed awkwardly in regards to the interior, too small for anyone over the age of 5 to get through, or too high on the outside from which to safely drop to the ground.
