- wrgrs50sExplorerI don't guess the author of this story has ever did any research on "cold seizing a piston in the cylinder by not allowing enough time for proper warmup" The piston will heat first and expand at a rate faster than the cylinder wall. It doesn't mean it will happen in all cases but the potential is there under certain conditions.
- Cummins12V98Explorer III
rrev wrote:
I don't buy it. All engine builders I know recommend getting some temp in the motor before putting it under load.
I agree it would not be a good idea to have RV attached sitting 100 feet from onramp start engine and take off. BUT starting and rolling right after start driving thru the campground and streets leading up to where you have to accelerate will not hurt a darn thing. - rrevExplorerI don't buy it. All engine builders I know recommend getting some temp in the motor before putting it under load.
- Sport45Explorer II
Cummins12V98 wrote:
wing_zealot wrote:
Cummins12V98 wrote:
I would suggest you not try throwing warm water on your -10 degree windshield.
While working I mostly kept my rigs in a shop. But there were sometimes that I needed to remove snow and de ice. That only took seconds to do as I would have a gallon pail full of very warm water to throw across the window and had a push broom to quickly remove the snow.
Everyone always told me not to do that, never had a problem down to single digits. Now I can't say -10 would be fine since I have not tried that!
It's my method of choice too. But I haven't tried it at anything less than -5°F. The water doesn't have to be hot. 80° water will melt ice just fine. In my experience it hasn't even increased the lengths of cracks or starbursts already in the windshield. I'll use the wipers to dry the glass after the water has melted the ice.
But keep in mind I'm a native Texan and it gets cold in East Texas but not as cold as up North. - PaulJ2ExplorerBest car i have for cold weather is the 2001 Prius. Blows heat in 30 seconds after start up. Electric ceramic heater boost until engine warms up and takes over.
Everyone always told me not to do that, never had a problem down to single digits. Now I can't say -10 would be fine since I have not tried that! - wing_zealotExplorer
While working I mostly kept my rigs in a shop. But there were sometimes that I needed to remove snow and de ice. That only took seconds to do as I would have a gallon pail full of very warm water to throw across the window and had a push broom to quickly remove the snow. - colliehaulerExplorer III
Fast Mopar wrote:
Keep in mind as well this (article) was written by a person from Florida where +40 is bitter cold to them. LOLLessmore wrote:
You need to warm your vehicle up when it's 35 to 40 below. We get this weather every so often and I get a bit of a yuk, when I hear this kind of advice from individuals in warmer climes.
Les, you are absolutely correct. I lived many years in climates where -30 to -40 temperatures were part of the normal winter. It's a different way of life, and if you have never lived through it, you should not just tell others how to live through it. At those temps, a car acts in a very different way even after it is somewhat warmed up. Reminds me of the phrase "If I have to explain, you wouldn't understand." There is a big difference between -10 and -40. - Fast_MoparExplorer
Les, you are absolutely correct. I lived many years in climates where -30 to -40 temperatures were part of the normal winter. It's a different way of life, and if you have never lived through it, you should not just tell others how to live through it. At those temps, a car acts in a very different way even after it is somewhat warmed up. Reminds me of the phrase "If I have to explain, you wouldn't understand." There is a big difference between -10 and -40. - Cummins12V98Explorer III
Perrysburg Dodgeboy wrote:
Cummins12V98 wrote:
"If you have a motor built in the last 30-40 years or so, it is better to turn on, take off slowly, this will warm up the motor faster and better."
I completely agree! I have NEVER let my rigs warm up. I get high miles out of my rigs with no issues. Start engine, place in gear and drive moderately to start.
So do you clear your truck of snow then start it and take off? Or do you start then clear and drive off?
Here is a oil report with 15K on the oil that I start and go with. Understand the Universal averages are from engines that drained the oil at MUCH lower mileage with the same engine.
