dmullenExplorerFeb 20, 2015Door CurtainsPlease post pictures of how you covered up the window(s) on your trailer's outside door. As you know at night you can see right thru them when there is a light source behind it. I'm just looking for...Show More
LadyRVerExplorer IIFeb 20, 2015I did the window curtain like the pic, using a small cafe curtain rod.Just make sure there is enough clearance between the door and the screen door.I also used a cover which CW sells, with velcro tabs on another rv.Edit: On another RV, I had enough room above the inside door frame to install a window shade. That worked good, too.
Related ContentBedroom door or curtain?side door bentFront curtainInterior windshield privacy curtain and door screenDoor lock
