blt2ski
Aug 29, 2014Moderator
Thunderbolt wrote:
I did weigh it. It is an extended cab,short box 4x4 with 6.0 liter gas engine and it was just under 5,800 without me in it. Of course the truck was empty. The diesel trucks of that year were around 7,000.BenK wrote:Thunderbolt wrote:
snip....
My 2003 silverado 2500HD, LS trim with gas engine has 2,732 lbs of payload and 9,200 GVWR. That includes a 150 lb person in each seat and full tank of fuel.My truck weighs 5,800 and I weigh 220 so technically I have 3,330 lbs of payload. I have had over 3,000 pounds in it and I assure you I wouldn't be comfortable with that weight on a regular basis. 2,000- 2,500 lbs would be more realistic.
Go out and actually weigh it...guessing you'll be surprised that it
will weigh closer to +7K lbs than 5,800. Betcha a Costo Dog Lunch... :B
Then everything else that is based on that 'curb' weight will be reduced...
My 88 ext cab with a BB and std 8' bed was a shade under 6000 lbs. The 96 CC diesel was 6600 or there abouts.......some rigs weigh more, some a bit less, depends upon options.....then again, My 2000 reg cab C2500 with TWO chargable options, ie auto trans, factory hitch, or and trim rings, is 4800 lbs!
Marty
