4ofUs
Jul 13, 2015Explorer
Double check the math. Not sure exactly how much I can tow!
Hey all, finally deciding to take the plunge and get ourselves a travel trailer. I have grown up camping in them, from travel trailers to fifth wheels to the classes, but now it's time I get my own.
I've spent all day doing the math on towing capability, and I was wondering if someone could double check my math and see if I'm doing this right.
I own a 2008 F250 5.4L (gasser, I know), Crew cab with tow package and 4.10 axl ratio. The numbers I have gathered are below:
GVWR: 9400 lbs
GCWR: 18,000 lbs
Max Loaded Trailer Weight: 11,700 lbs
RAWR: 6100 lbs
At this time I do not know the exact weight of my truck but I have no tool boxes or other additions.
I used the calculator at http://changingears.com, which told me that the max trailer weight should be around 8600. Adding in safety margins of 10% that would put me around 7740 max trailer weight.
At first I thought this was low, but the more I'm reading it might be accurate? I've tried to provide as much information as I could that I know, do these numbers make sense to anyone else? I've also seen plenty of people that towed more weight, but I plan on being safe and staying within my limits so I don't want to just overload it because I can.
GVWR: 9400 lbs
GCWR: 18,000 lbs
RAWR: 6100 lbs
