westend
Jul 13, 2015Explorer
4ofUs wrote:westend wrote:
What is your payload rating?
It will have more effect on what you can tow than anything else.
If that is the max payload capacity, I just looked it up and it showed 2850.
Do you have the camper package? Regardless, the weight sticker should be on the driver's side door jamb. F250's are all over the map, depending on what you have. I have 4x4 and that derates the cargo capacity significantly. I also have a 3.73 rear end so my towing weights will be less than yours.
44,056 PostsLatest Activity: Nov 19, 2013
