ThaiExplorerMay 04, 2018Double Propane Holder Doesn't Fit?How are people mounting your double propane brackets? Mine doesn't fit and would rather not try to cut and remove the existing braces. Only other thing I can think of is getting some sort...Show More
Farmboy666ExplorerMay 06, 2018I thought the marine plywood was a good fix, you could cut the vertical piece off the rear angle also
