marquette's avatar
marquette
Double stack receiver hitch
Has anyone tried one of the double stack tow bars or hitch. I'm not sure of the correct term but they are the ones that go into the receiver and allow for a bike rack to be mounted and a still be able to tow. After reading all the negatives to adding a bike rack to the rear trailer bumper I was wondering if this is a better idea. Trailer is only 14.5 ft long and weighs under 2500lbs loaded. Towing with a 2001 1500 Suburban. Etrailer sells double hitches and so do several rv suppliers but that doesn't necessarily mean they work.
  • I used one while towing a small utility trailer. They are not intended to be used with weight distribution and the receiver must be derated when using any extension.
  • I have used those in the past, you severely reduce the hitch rating, but if your trailer is under 2500 / 250 lbs with a hitch rated for at least 5k, I wouldn't worry about it. I would use the shortest stinger I could find and be careful on bumpy roads...
