Tom/Barb wrote:
rjstractor wrote:
However, as has been stated, a modern diesel (or even one like mine with an add-on) with an exhaust brake will provide significantly better engine braking than a gas engine, mostly by virtue of a much higher compression ratio.
That's not true with a Cummins. They really don't have an exhaust brake Like a Caterpillar.
Well are you referencing an exhaust brake or engine brake?
Newer exhaust brakes are handled with variable turbos, not a true butterfly valve like a PacBrake. Engine brakes typically alter the valve train operation.
