rightyouareken
Jul 16, 2013Explorer
Our trailer is 8' (96") wide and has a 60"x74" bed lengthwise in the front of the trailer. This is sometimes called a walk around bed since you can walk around either side of it to get in. There isn't a ton of room on either side in our trailer (18" on each side doing the math... 96-60 = 36/2 = 18"). With a 7' wide trailer you'd reduce that quite a bit. Looks like it would leave you maximum 12" either side of the bed, maybe even less allowing for the thickness of the walls. Any wardrobes next to the bed would also be smaller. Might be pretty tight.
44,066 PostsLatest Activity: Jul 25, 2018
