FishOnOne
Oct 05, 2014Nomad
Turtle n Peeps wrote:FishOnOne wrote:Turtle n Peeps wrote:I guess I should have worded my last post differently. The older Cummins made more power at highway cruising speeds making it feel like it was just loafing along.
:h :h
I don't know how old your talking about but my 2006 Duramax put out 198 HP at 1600 RPM and the same year Cummins puts out 185 HP at the same RPM.
The 2004 Dmax put out 158 HP at 1600 RPM and same year Cummins put out 122 HP at that RPM.
The 2002 Dmax puts out 152 HP at 1600 RPM and the same year High Output Cummins put out 153 HP at the same RPM.
As you can see, most years the Dmax beats the Cummins at low RPM power or is very close.
Both of you guy's statements are misleading. The HP numbers you are reporting is at Wide Open Throttle (WOT).
And I don't consider loafing around means running at WOT.
Troy, quit it. :S Are you saying that my LBZ is only putting out 185 HP at WOT? LOL :R Do the math.
My figures are at 1600 RPM. You know, the RPM I'm at 95% of my towing time.
So are you saying that your LBZ put's out 198 HP at 1600 rpm with a very light throttle similar to what you run down the highway unloaded?
Every engine dyno plot I've seen has been done at WOT which means you can't simply pick a point on the spectrum (i.e. 1600 rpm) and expect that to be the HP running down the highway with very light throttle at 1600 rpm.
