Kylesmith3021ExplorerApr 16, 2016Draining fresh water tankWent to drain fresh tank after sanitizing it and its literally a small valve that takes over an hour to drain..Am i missing something here?? Its located under trailer below water fillup
NunyadamnExplorerApr 16, 2016I will pump it into the grey tank. It takes forever if I don't for the 80 gallon tank. Takes about 15-20min by using the pump.
Related ContentFresh water drainFresh water tank drain.Fresh Water DrainFresh water drainHouse battery drain
