myredracer
Apr 17, 2016Explorer II
If you have an outdoor shower you can run the pump at the same time. Also pumping into the grey tank at the same time should help providing you can dump the tank where you happen to be.
If you need to do this often, I wonder if it would help to install a 1/2" to 3/4" or 1" PEX coupling and a ball valve for better flow. I installed a tee and valve right at our pump so I can attach a hose directly at the pump - pumps water out somewhat faster than using the outdoor shower or a faucet. Nash has a good setup for fast draining.
