JW2's avatar
JW2
Draining fresh water without removing camper from truck.
All of the campers I have had in the past have had minimal amenities, and as such I didn't need to worry about much. My wife and I have recently been fortunate enough to have purchased a 2008 Northern Lite Classic 9-6. We just got back from a 4 day trip to Eastern Washington. The temperature will be in the mid 20's here at home the next couple of nights. I left the heater on tonight because we did not have time to properly drain the fresh water tank. Anyway, I would like to drain the water tank without having to unload the camper, if possible. I know that I can drain the camper water by just letting the water empty into the truck bed, but is there an easy way to empty the fresh water tank without having to remove the camper or dumping the water into the truck bed? Thanks in advance for your help.
  • turn on the outside shower if you have one, that way you don't have to dump.
  • turn on the shower ... let it go into the grey...dump. ??
    But you need to drain the hot water heater unless you are going to keep some heat in there.
