mooring_product's avatar
Aug 18, 2014
Draw-Tite Front Mount Trailer Hitch Receiver
Installed the hitch over the weekend. I like how easy it is to mount and how high its off the ground.
Only issue I had is they forgot 4 bolts in the mounting kit.
Ill be putting my chest style tool box in the front so I can put gear in it such as chairs and a 2000 Honda.
Started with this
New front receiver and new RV faucet by MooringProduct, on Flickr
Installed tape to prevent damage to the chrome.
Removed the grill to get to the top inside bolts..really didnt need to but it was a little easier. Tow hooks off.
Installed minus 4 bolts.
Oh ya..all the stickers were upside down..it was confusing when mounting it..I removed them for a cleaner look.
Part # 65063
  • jimh425 wrote:
    I like the mount being higher, but the main disadvantage is I need a front license plate! That's why I had to go for an under bumper model.
    Instead of mounting the license plate UP from the bottom license plate holes, you could mount it DOWN from the top license plate holes.
    The difference between Ford, GM or Dodge may make this point moot.
    I wonder how to check for intercooler temperature difference. Does the OBD2 port show intercooler temp???
  • I like the mount being higher, but the main disadvantage is I need a front license plate! That's why I had to go for an under bumper model.
  • Jaxom wrote:
    Very nice. I've been considering a front receiver myself.
    Will you get a chance to determine if coolant temperature is affected?
    Coolant shouldn't be an issue. My concern will air flow through the intercooler.
  • Super_Dave wrote:
    Did the license plate mount above or below the receiver before you mounted the hitch?
    Don't have front license plates in FL but you can see the two plastic screw inserts below the hitch in the pictures.
  • Very nice. I've been considering a front receiver myself.
  • Did the license plate mount above or below the receiver before you mounted the hitch?
  • Nice job :) I like all the pics too. I like the horns, the bar with urinals, the rock feature pool........you're living the dream. Very nice.
