- Cummins12V98Explorer III
ACZL wrote:
Thanks for all the tips gang!!!
Cummin12V, what is that stuff and where do you get it?
I put Rain-X on as well when done, but just was wondering if the 2 I asked about would work w/o scratching the w/s. Up till now just been using elbow grease and wash mitt.
AMAZON is one place.
A guy was proud of getting his boat glass clean on another forum but what he did was very time consuming. I said too bad he should have tried it. Another boat owner did try it and was so amazed several others have now bought it.
water spots come off with ease. - ACZLExplorerThanks for all the tips gang!!!
I put Rain-X on as well when done, but just was wondering if the 2 I asked about would work w/o scratching the w/s. Up till now just been using elbow grease and wash mitt. - cptqueegExplorer IIDryer sheets will prob leave a film. My appliance installer just reccomended not using dryer sheets in our new dryer due to the residue they leave behind.
- BenKExplorerWaterless hand cleaner
Biodegradable, or at least the one I use
Tough buggers...scrape the waterless hand cleaner with an old credit card
Then use the washer fluid and wipers (am assuming out on the road where a hose isn't available) - wopachopExplorerMagic eraser works great on glass. When i watch auto detailing videos the guys say the foam acts like 4000 grit sandpaper. There is no special cleaning chemical inside. The water is just for lubrication.
You can use a spray cleaner instead of water. - C_B_Explorer II
Thermoguy wrote:
What are you trying to clean with dryer sheets? There might be something better...
Bugs! off windshield and front cap. Works great! - ThermoguyExplorer IISteel Wool, Flat Razor blade for stickers and such, there are lots of things you can use to clean a windshield. The glass is not very easy to damage. If you have oils and such that just smear while using your wipers, try RainX as a cleaner or F11 if you use it instead of wax. Or, just glass cleaner. I usually use RainX anyway and clean my wiper blades at the same time, so I don't let road oils mess up my windshield. Lately I have been using F11 instead of wax and it cleans the windshield better than anything else I have used.
- AvaExplorerUse 0000 fine steel wool. I use it all the time without harming the glass. Will clean anything off the glass.
- Cummins12V98Explorer IIIThis "SPECIFIC" brand is AMAZING for cleaning spots off glass.
- ACZLExplorer
Truck windshield
44,055 PostsLatest Activity: Dec 23, 2025
