resq302's avatar
resq302
driver side brakes heating up way more than pass side
Since this is my first post, mods, please move it to the appropriate section if this is not the right area.
Recently, we had an issue with our Pace American 24' enclosed car trailer with the brakes on the driver side heating up to the point of bubbling the freshly painted rims. I just replaced the backing plate assembly with new ones for all 4 wheels and had the drums machined. When I pulled the driver side wheels and drums, the red grease was now a dark brownish color and had lots of metal flake in it. 3 of the 4 bearings were scored so I replaced them all with new Timken bearings and races as well as putting new seals on. Whats weird is the driver side and pass side bearings were adjusted the same way.
After replacing the bearings in the driver side, greasing the bearings, and adjusting everything, we took the trailer out for a drive now with our antique car inside for weight to test it out. After a short drive, the same thing happened. What am I missing? We are going to be traveling about 3 hrs driving out to Hershey, Pa coming up in the next couple of weeks for a major car show and we do not want to either have the grease in the hubs catch fire or be stranded on the side of the road.
Can anyone suggest what I might check next?
Oh, we had 10 volts at each of the magnets for each of the 4 wheels. Voltage read anywhere between 10.2 to 10.6 volts at each of the wheels.
  • Tell us exactly how you are adjusting the wheel bearings and the brakes.
