Fastbrit wrote:
These are the minimum requirements to obtain a beach permit in Cape Code;)
Vehicles:
4-Wheel/All Wheel Drive Vehicles or Self-Contained recreational vehicles must have: a valid state registration, inspection sticker, insurance, tires meeting standards outlined in this brochure and all required accessory equipment.
RENTAL VEHICLES ARE PROHIBITED.
Vehicles will be inspected for required accessory equipment:
Shovel: Heavy-duty shovel equal to a military folding shovel
Towing Device: Any of the following which are at least 14 feet long:
Tow Strap: 1.5"; Rope: 3/4"; Chain 5/16"; Cable 1/4"
Jack: Standard size (e.g., vehicle manufacturer's jack)
Jack Support Board: Wood: 10" x 12" x 1.5" or Plywood: 10" x 12" x 3/4"
Tire Pressure Gauge: Must register to 5 p.s.i. or lower
SCV's and pick-up truck campers must also have a fire extinguisher and permanently mounted holding tanks for gray and black water.
Spare Tire: Must meet tire standards outlined below. Important Spare Tire Information
Tires: All 5 tires, including the spare tire, must meet or exceed the standards outlined below. NOTE: Many newer vehicles are being produced with temporary (smaller) spare tires; be sure to carefully, physically check your spare tire size for compliance before applying for an Oversand permit.
These standards are minimum acceptable tire standards.
19 inches wheel 265\50R19 with matching spare
16 inches wheel 235\65R16 with matching spare
Dual-Wheel Standards for R/V's and
Pick-Up Campers (including spares):
Self-Contained & Pick-Up Campers
LT245\70R16 Front with matching spare
4 rear wheels section width have to be 8 inches minimum with matching spare
Tire Pressure:
You are required to decrease tire pressure before entering the beach ORV. Tire pressure is critical for successful oversand driving. 11 p.s.i. is recommended. Friction may cause pressure to increase while you drive making it necessary to stop and reduce pressure again. Your beginning tire pressure should not exceed 15 p.s.i. An air compressor for inflating tires is located in the parking area between the north and south access areas at Race Point.
Thank you! great info. I actually meet all of those specs :) Eleven pounds. Wow that is low! I think I will try a little more than that at first.
