I've seen that pic before, maybe even a vid of the Atlantic swallowing the beast. Grim. It looks like the floatation ability of the Lance over came the tie downs of he truck incurring a separation of the two. The P.O.V. is that there is sand and there is sand. Wet or dry, it's your job to know what you are getting into.
I always prefer someone watching my back when I get into the soft stuff. In most cases it's my brother John and his '99, 2 series Ford with OUTFITTER! The rule of thumb is it takes a machine of at least equal weight, flotational ability and extraction technique to pull your sorry rig out of the bottomless. I learned this over and over when I was a hard core Jeeper. I had a friend who was in the Hummer I (Mil. Spec. HumVee) crowd in AZ. When occasionally stuck, no number of tinky little Jeeps with multiple straps or winches could pull him out. Along comes another hummer and, Voila! no more stick. Here's a little story I've told before on here that illustrates the process you must go through before you can pull a MUCH larger vehicle than your out of the sand.
About 1967 I was driving a rag top Toyota Gland Bruiser, FJ40 with factory PTO winch.I upped the ante on the capacity of the winch by drilling out the shear pin hole to accept 1/4 inch drill rod. We had a chance to camp on the dunes at Pismo Beach, California and do a little Clamming. I had big wide 'Hi-Flot' tires, basically farm implement tires from Dick Cepek that you could run at low pressure.
On the way out we came upon a 45 foot MoHo, I think it was a 'Condor', who had descended below the tide line and subsequently dropped this 18K pound boat anchor to the frame with his trailer hitch submerged under the sand. I was in a much more forgiving mood then than I am now and took pity on this wide eyed couple. During a pre-pull chat, i told him to deflate all 6 (or maybe 8 as i think he had a tag axle) of his rock hard tires from 110 pounds down to 40 pounds. He also used my shovel to make little ramps in front of all his tires to decrease the resistance. This took a while so I readied for the extraction. Meanwhile a large contingent of onlookers appeared to see if the result was going to be like the camper pic above. What in the hxxx was this mad guy in a red jeep doing? I first measured back about 80 feet in front of the MoHo to give the least amount of courses and the greatest pulling power on the winch drum. I reeled out the winch cable almost all the way out, about 100 feet and had no good winching point on the MoHo so just wrapped it around the solid front axle of the truck chassis. and hooked onto his rig and took out the slack. Then turned the hubs off and slowly backed up against the MoHo, burying the rear axle to the frame. Then turned them back on and buried the whole rig trying to back against the winch line. I became the defacto dead man. The hook had no clip, which turn out to be a good thing. All was set. I told him, "once you get a little momentum, do not stop but make a wide arcing turn and go back the other way." I also bade him not to spin the tires. Go easy on the stupid pedal. Yeah, sure. I started in low range, low gear on the PTO and the Leviathan started to move, ever so slowly out of its temporary grave. I shifted to high gear to get more line speed. It worked. He got tipsy with actual forward motion and floored the bohemouth. Lucky the winch line fell off as he made a wild and crazy 180 around me to faint applause, sand flying and engine roaring, and never looked back. We never saw him again. Lucky for him there was air available at the beach head to reinflate his tires for the highway. jefe
