pcoplin's avatar
pcoplin
Explorer II
Apr 29, 2015
Dropping camper on sloped driveway
I need to do some work on the skirt (rebuild likely), and would like to do it in my driveway, but off the truck so I can go get a full sheet of plywood.
The driveway slopes about 5 degrees. There is a 10 inch drop from the back jack to the front jack.
I was thinking about cutting some 6x8 blocks to match the driveway slope so the jack feet will be level.
What do you think?
The truck makes it look worse, look at the driveway expansion line.
  • If you do make sure that the unit is really level, I'd be worried about a jack collapsing if it was unlevel.
