specta's avatar
specta
Drove through a weigh station this morning.
Front - 3620
Rear - 6960
tag on the door,
Front - 4400
Rear - 6200
GVWR - 9500
I think they need to calibrate their scale. :B
  • deltabravo wrote:
    Who is "they"?
    State operated scale along a highway?
    CAT scale at a truck stop?
    tongue in cheek comment ;)
  • specta wrote:
    Front - 3620
    Rear - 6960
    tag on the door,
    Front - 4400
    Rear - 6200
    GVWR - 9500
    :B
    Who is "they"?
  • Pretty close. What are your tires rated at the pressure you were running? My bet is the stock rear tires are the cause for the RAWR, but of course, Es can go all of the way to 4080 each or down to barely 3000.
  • Kayteg1 wrote:
    It is only 11% above RAWR.
    Just don't go on freeways.
    Is it with booze loaded?
    If it is over the RAWR bet it is Over the tire load ratings also
    2500 with a 2800# DRY weight camper and one thinks scales are wrong ?
  • It is only 11% above RAWR.
  • Those are axle ratings on your door, not weights. You can bet those scales are not off by much if at all.
