brirene wrote:
OP here. Planning to go with 2 new ones in front, fronts to inside, and oldest on outside, as a couple of you suggested. For those who mentioned the spare, it's actually a different brand, so that won't work long term. Original owner changed them out at some point. Thanks for all of your input! It was quite helpful.
I just mounted two new front tires for the 2nd time and I'm very happy using your new plan. Be aware tho that all 6 tires will have to be re-mounted if you want your truck looking nice when it's complete as some rims are steel and some rims are polished on one side. Also think about valve stems if your tires are hard to inflate or if you are getting slow leaks. Simple replacements can make a difference.
