Kayteg1 wrote:
billtex wrote:
The latest gen SRW offer as much “capacity” as previous DRW. .
You must be talking taxable capacity?
The highest rating for truck tires I found was about 3000 lb.
So unless you go to 19.5", you will have 6000 rear axle rating minus 3000 truck weight leaves 3000lb rear cargo for SRW.
Add 2 more wheels and you have 9000 lb rear cargo (with slight adjustment for bigger DRW weight)
Adjust the numbers to your actual truck, but the final will not change much.
I replaced my stock tires with 20" Nitto Terra Grapplers and they are rated at 3750 each... NOT 3k
