transamz9 wrote:
Lantley wrote:
transamz9 wrote:
OP, unless you are planning the over double your trailer weight a SRW now days will cover you. Some people think you have to have a DRW to haul groceries. My total combined weight is 27,000+- and I am longer than any so called "Big Dog" on here. I am perfectly comfortable and have zero stability issues. ;)
While I understand you are content and satisfied with your SRW set up
I believe a dually would provide a better tow than your SRW combo.
If I'm understanding your numbers correctly the the loaded weight of your RV is 17-18K?
No, I pull a 5000# boat behind my fiver.
Got it. That does change things as it puts the GVW of the trailer more in the 13K range which aligns more with the capabilities of a SRW truck.
