kohldadExplorer IIIOct 24, 2014DRW regrets?For those of you which have gone from a SRW truck to DRW, do you wish you had just gone with a lighter TC and stayed with a SRW?
805greggExplorerOct 24, 2014If you drive off road much, you will get rock stuck between the rear tires that will cause blowouts, learned that in Baja, kept getting flats and when the tire went flat the rock would drop out, so couldn't figure it out
