sidney
Oct 05, 2013Explorer
DRW Stability
Been reading the SRW vs DRW threads... I have never towed with a DRW and I'm curious what everyone means by "stability". Can you describe what you're experiencing that feels more stable. To say ...
transamz9 wrote:
An E rated tire at 50 psi is no stiffer than a p rated tire of the same size at 50 psi. The sides walls on all these tires are 4 ply. The differences are in the tread plys. If you put 80 psi in a passenger tire it will have no more movement side to side as an LT tire at 80 psi.
