Grit dog wrote:
Lantley wrote:
fj12ryder wrote:
FishOnOne wrote:
Also I don't believe there's any braking performance benefits of a DRW vs a SRW truck. Perhaps a slight advantage of a DRW additional wheels to dissipate heat from the rear brakes.
Hmm, I would think the additional friction material on the ground, i.e. 6 tires instead of 4, would offer more than just a slight advantage. I'm referring to better braking while towing.
More rubber on the ground is a significant, noticeable advantage.
Fish is right, until you exceed the tractive capabilities of the tires and pavement. But who’s to say “half” the ground pressure x twice the surface area won’t yield the same results? Depends on many other factors
Lantley, by your analysis, duallies have worse braking performance since front brakes do more work than reads and front tires on a dually have a smaller contact patch.
Another ad nauseum thread down the drain.......whooosh!
I did mention in my post that I was referring to "while towing" when much more of the weight will be on the rear wheels.
