FireGuard's avatar
FireGuard
Explorer II
Mar 10, 2017
DRW with TC in sand
I'm curious how a DRW with a large TC towing an ATV trailer with a weight around 3k lbs compares to an empty truck towing a large toy hauler weighing 12k lbs plus?
I know the wheels don't track as well as a SRW but I would think with the weight on the truck and having to drag less weight through the sand would be better.
What are the best techniques to make a DRW perform in the sand?
Is it possible to air down enough to drive 3-4 miles without damaging the tires or maybe use spacers to create more space to air down?
  • Fpoole
    I assume you didn't air down with your 19.5 tires?
    Hard sand would be good, but there are times when you need to drive through the soft stuff.
  • live and learn... Some do, some don't. Don't can be expensive.
  • ".... Packed stuff"...
    Yah, I echo that one...
    I got stuck... Luckily a nice TC was near by and offered to pull me out.
    Lessons learned...
  • I use Maxtracx, but I didn't pay nearly this price for them. https://us.maxtrax.com.au/
    I use them pulling an 18k trailer through mud/sand/other when needed. Sand isn't so bad as long as you stick to the packed stuff.
