AH64ID
May 08, 2015Explorer
jaycocreek wrote:It works for you and there is no disputing that but it's hard to recommenced something to others when you have no actual data of your own and the specifications are not even close to working as you described.
Okay, being exact, although I said "approximately" . What I found is exact and good to know for those that want to be exact in everything that they do! If "exactly" drained to 50% it will take 5 hours at 10 amps to be "exactly" 100% full.
I think 3~4 is close to 5 but hey.
5 hours is a 66% increase over 3 hours.. but hey. 5 vs 3 is big in terms of generator on time, and the resultant charge.
Yes, it would take 5 hours in a perfect world. As I mentioned most chargers do not charge at a fixed amperage they apply max amperage until the set voltage is obtained and then they taper amperage to maintain voltage (this can be seen in the graph I posted above). So 5 hours on a 10AH charger will not net 50AH on a 110AH battery, it will be lower.
Batteries can only be partially charged so many times before they need a full charge (12-18 hours of charge) so they do not develop a memory and lose capacity (AH).
44,025 PostsLatest Activity: Feb 26, 2025
