vlopddap's avatar
vlopddap
Dual AC option on 27 foot trailer?
Our favorite travel trailer ever is a 27 foot Sunset Trail trailer from Crossroads RV (30 foot tongue-to-bumper, but 27 foot usable floor) and this unit come standard with a single 15,000 BTU. But as an option you can get a second 13,500 BTU A/C (I don't know why they are different sizes, but who cares...). BUT, when you choose the 2nd air conditioning option, it comes with a forced upgrade to a 50A service instead of the basic 30A service! Moreover, what we observed yet, is local dealers tend to order this options for stock's units, but not all of them as well.
A 50A service sound like a complete deal breaker for me because it drastically reduces the range of options on campsites especially for a pretty small trailer of 27 foot.
Just wanted to have your quick opinion, mostly regarding the need of two AC for that size of trailer versus the fact of having a 50A service, because we saw a lot of 33-35 foot trailer with a 30A service...
  • schrederman wrote:
    The 50 amp plug has one hot leg that's 30 amps like a normal trailer, and runs most of the stuff, including the first A/C. The second hot leg is usually breakered at 20 amps and is for the 2nd A/C and/or electric fireplace if equipped.
    Good grief! :E Time to read up on 50 amp RV service.
  • I'm sitting here at a 30 amp hookup using a 50-30 amp dog bone with both of my A/C's running to cool down our 42' fiver. I must run my water heater on propane and can't use the microwave when both units are on but no big deal.
    Too answer your question a 50 amp service can plug into a 30 amp with no issues using a $20 adapter.
  • I had one the same size as yours. The only time I wished I had a second unit is from around 1 pm to about 5. It would get a little warmer than I liked, but a couple of small fans helped a lot. Same in my current trailer, 33' box. Not going in and out a lot also helps. Once the sun starts going down a little, the 15,000 does a nice job. Most parks charge a few extra dollars for 50amp.
  • A lot will depend on the insulation of walls, floor and roof. Dual pane windows and mini awnings on each window and my single 13,500 can keep me at 65 degrees inside when it's 105 outside in full AZ sun.
    Low humidity also helps in my case.
    If you park in full shade that could be a huge advantage.
  • 15K AC is fine for us in a 32 footer with 2 slides in direct Myrtle Beach sun every summer.
    50 amp would be nice though.
  • :) Hi, no-one seemed to mention the weight and bulkiness of the much larger cable of the 50 amp service. In really cold weather my 30 amp cord is difficult to roll up. I had to bring it inside of the trailer to thaw out so it wouldn't break.
  • Our unit is 30' and came with a 15k BTU unit and a 50amp cable. I can hook to 30amp anywhere with the 50a to 30a adapter. It came with a 50amp cable because the bedroom is pre-wired for me to add a 2nd AC unit. I'd rather be prepared to upgrade rather than not have the option to upgrade due to being wired for 30amp. We live in Florida and there are lots of spots with no shade coverage. the 15k unit will cool us down just fine, but it tends to run for a long time when its super hot out and no shade. I may eventually add the 2nd one just to keep the bedroom cooler, but I'm in no rush. In a pinch I had to plug into someone's house to run the AC while my dogs stayed in the trailer and I used the 50amp to 30amp adapter and then plugged that into the 15a adapter to be able to plug in to the house. I checked everything periodically and the cables never over heated and it worked like a charm. Don't fear the 50amp!
    That is a great point. Wrangling our 50 amp when its cold is a pain the arse. They just don't want to roll up into a nice roll and go quietly into the there compartment.
  • Thank you very much guys for the great comments. Yes, weight is also a good point because a 13.5K roof unit weight at least 100 pounds with accessories...
    My own conclusion is it doesn't worth the upgrade for a second A/C on a trailer that size.
    Thanks again! :-)
  • One nice thing about having a dual AC system is that you have a spare if something goes wrong with one of them. We have two in our LaCrosse 329 and normally only run the one in the rear bunkroom. The "white noise" from the AC helps the kids go to sleep and does not bother us in the front. We only run the front one when trying to cool it off quickly on a toasty day.
