AnEv942 wrote:
I added small pings tanks. They, other than improving ride, did take out that impact under hard fast hits, so in a way did remove some of the shock seen by brackets.
There's something I hadn't considered. Lessening the shock to the upper brackets by adding a reservoir tank... OK that's just been added to the project list!
I wonder if those little air lines are too restrictive to allow enough airflow to respond quick enough to road bumps. I can't do anything about the size of the fittings on the bags but I can use bigger lines to the tank at least.
