Hodag1's avatar
Hodag1
Dual alternator as a generator
On the EarthRoamer site they say;
"We order Ford F-550 turbocharged diesel Power Stroke trucks with the dual alternator option which provides a quiet, fuel efficient, factory installed 3.7 kWh generator. We install an advanced battery isolation system and connect the factory alternators using low resistance, #4/0 tinned copper marine cable to the massive absorbed glass mat (AGM)camper battery bank. Whenever driving or the engine is idling, the AGM battery bank is being charged by the high output dual engine alternators. At idle, the Power Stroke diesel burns approximately .5 gallons of diesel per hour which is significantly less than many RV generators at full load."
I have a 2011 F350 6.7 diesel with dual alternators. Has anyone on this forum done this? Is there a source of premade cables and ancillary hardware to accomplish this?
  • I can also charge from the TV alternator if solar is not enough (bad weather). One thing you might want to look into is a Balmar regulator/smart charger http://www.balmar.net
