93Cobra2771
Jun 29, 2015Explorer
I'd say give it some miles and see what happens. I'd also see if you can tell how the mating surface looks between the bars and the cams. A light coat of spray paint on the bars and then a trip around the block should tell you pretty easily.
You could also put a light lube of Vasoline and see if that encourages them to release a little easier.
And finally - your heavier bars - are you sending more weight forward than with your lighter bars? It could be that simple. They aren't giving as much as the old bars and simply have a tighter grip.
44,025 PostsLatest Activity: Feb 18, 2025
