CampingN_C_'s avatar
CampingN_C_
Dual Cam question for guys towing heavy.
I've just recently gone up to 1500lb spring bars and having some issues in tight turns such as in parking lots. It feels as if the bars are not sliding freely on the cams. Hard to explain but, once I turn to a certain point I hear a wicked bang, BUT I also feel it in the truck quite a bit. I know the DC makes noise but I not talking about the normal stuff.
I did noticed when I got the new bars that the bend at the end was was more pronounced than my 1200lb bars, even posted pics here on a thread.
It's like they're binding up and then finally popping lose on the cam, which is why it rocks the truck. I've stopped and looked while in the turn and all looks fine.
I've never put any sort of lube on the cams.
Any ideas?
  • I occasional had the same feeling on mine as well. Enough that the whole truck shook occasional. I imagine as they are used they will loosen up a bit. Did you get new bars only? If so, it could just be the bars getting acclimated to the worn saddles.
