smcrea's avatar
smcrea
Explorer II
Aug 21, 2012
Dual Rear or Single Rear Wheels on Tow Truck?
Hi,
I'm starting to research Trucks that are suitable for a TV.
I've read the the HUGE discussion on Diesel vs gas so lets not go there! :-)
This question is: Do I need Dual wheels or single wheels?
We currently have a TT that we tow with our GMC Yukon XL 90+K miles but really struggled when we just did a 4 week trip from San Diego to Jasper NP in Canada vi Utah etc and back via Washington and Oregon.. Given the advancing miles and the prospect of doing even longer and tougher trips with my young family then its time to replace the Yukon while I still have some re-sale left in her.
We may sell the TT sometime in the future and get a 5th wheel that is MUCH heavier.. who knows? So my spec for the truck needs to be based on possible future trailers or 5'ers rather than our existing one. I don't want to be limited by my TV when it comes to choosing a new RV.
So with that said.. should I choose dual or single?
What are the advantages and disadvantages?
Please can you give reasons for your opinions?
Many Thanks!
Steve
  • Thanks for the reply!
    I would like to dimension the trucks capabilities so that I will not be limited in the future.
    Just to show my ignorance could you remind me what GCWR stands for again?
    If I understand correctly then in layman's terms that a DRW gives you a much higher tongue weight capability than a SRW if we're talking about TT's. Not sure how that relates to 5'ers though??
    I can let the cat out of the bag and say that I'm pretty keen on a 3500 Diesel..
    Something like: 3500 Truck
    Would this truck serve me well regardless of my choice of future TT or 5ifth wheel?
    Thanks Again!
  • Hi Steve. Your question is pretty general so hard to give specific advice but it all depends on what you are thinking about buying in the future. This advice is not true in all cases as it depends on some specifics but a good general rule of thumb for the modern trucks (couple years old)is:
    3/4 ton or SRW 1 ton for up to around 12k GVWR FW. The SRW vehicles are generally limited by payload capacity on the rear axle and tire ratings. You could go gas or diesel with this combination based on your preference
    If you are going over 12k GVWR (and definitely over 14k GVWR) trailers you need a dually to get the payload capacity. With dual wheels you generally become limited by the GCWR at that point. This is diesel land in a pickup I wouldn't even think about gas unless it was the ford v10 (dodge and chevy don't make a gas big enough in a pick up any more for this load)
    There's no real advantage or disadvantage with dual wheels in non towing activities IMHO. I use a dually as a daily driver and put it anywhere you can put a car including parking garages.
