ognend
May 18, 2023Explorer II
Dual tank fill-up to top
Hello all.
I am 7,000 miles into owning a brand new '21 Chevy crew cab, cab chassis 4x4 DRW gas truck that came with dual fuel tanks (40 + 23.5 gal).
In the whole ownership of the truck, I have successfully filled it up full maybe 1/3 of the time.
It is my understanding that you are not supposed to use the front tank for fill-ups, correct? I tried a few times and it spat fuel back immediately so I concluded that the back tank is to be used. The way I understand it is that fuel flows from back tank to front tank, yes?
When I use the back tank, I have to open the front tank first to "depressurize" (get air out of) the whole system - this I found out on my own - without that the back tank spits fuel out as well. Is this correct?
After I do this, I am able to fuel up but often I can only get to between 3/4 and full on the gauge. After that, it spits fuel back from the back tank as well.
What gives? Is my fuel system faulty or is this normal? Are they this finicky? Thanks!
