Jimster's avatar
Jimster
Dually Chains?
We have a F350 4x4 dually with an Arctic Fox 811, and plan on using the rig through many of the coming fall and winter months in BC, Yukon, ID, MT, OR, CA and WA. I found that Washington State requires trucks with a gross weight of over 10,000 lbs. to carry chains (actually, two sets of chains) and British Columbia also requires all vehicles to have M&S tires or chains between Oct. - Mar. 31. I realize that our rig with its BFG Rugged Terrain T/A tires will probably not have any problems in the snow, but I like to be prepared for the worst.
Do those of you with truck campers on duallies carry dually chains, or do you mount single tire chains on your outside tires? I've read pros and cons for both, and recently found a good Internet price on dually chains. My Jeep and I were pulled out of the snow on Bannock Pass with a chained up dually in Montana once, and I am inclined to pop for the dually chains.
  • Dually (dual chains) sound like a lot of complex work to install them, as well as trying to keep them tight.
  • wnjj's avatar
    wnjj
    Explorer II
    WayneLee wrote:
    In California, it's either CHAINS REQUIRED,or no chains required. There is no in-between. The CHP determines when chains become necessary and, after that, all vehicles must put on their chains. On duals, only the outer one is required. No snow tires are acceptable.
    Can be very bad when you don't have chains and you are caught in a sudden snow storm. You have to sit there alongside the road until you either purchase some from vendors waiting there just for this situation or wait until the roads are opened up by the CHP. Don't ask me how I know this...
    There are 3 levels, much like many other states. http://www.dot.ca.gov/hq/roadinfo/chcontrl.htm
  • In California, it's either CHAINS REQUIRED,or no chains required. There is no in-between. The CHP determines when chains become necessary and, after that, all vehicles must put on their chains. On duals, only the outer one is required. No snow tires are acceptable.
  • Single chains are a lot, lot, lot easier to put on. Carry a piece of 2x4 or 2x6 about 6 - 8" long. Run the inside tire up on it, then you have room under the outer tire to put the singe chains on - it's rather easy even.
    If you thought one set of singles wasn't going to be enough traction, then carry another set and put them on the front end. If you're front tires can't grab to stay up on a curve or get traction to steer, then you aren't going anyplace.
    On May 26th this year I headed south from Alaska in my truck. Got down into northern Canada (where the leaves were all out and the farmers were planting the fields) and ran into a snow storm that dumped 8" in the mountains. It was interesting to watch everyone when the traffic started to move again - especially the RVs.
    Most of the problems were where everyone came to a stop because the tractor trailers that went off of the road. Most of the problems for the trucks pulling TTs or 5ers and DPs was they came to a stop on the banked curves. When they tried to start out again, their drive wheels just went sideways taking them closer and closer to the ditch or guard rails. One guy came through with a large toy hauler and he was chained up front and rear. Wasn't having a problem starting, stopping or steering, just kept moving at 10 - 15mph.
    I plowed snow in the hills above Anch for years, when the roads got slick, I chained up front and rear. I got stuck sometimes with only rear chains, but never with all wheels chained and I always had a large fuel tank in the back for weight.
    Bill
  • I carry chains for the outer wheels, must admit that I have never used them.
  • Hmmm. Good question. I had no idea that there was a 10k threshhold. Thanks for asking this
  • Back in my plowing days, I only used outer chains, and that was rarely. I had a hydraulic salter so I had enough weight back there for traction.
