Grit_dog
Mar 01, 2022Trailblazer
Cummins12V98 wrote:
"2019-20 model Ram CTD switched to the Bosch 4.2 lift pump. Switched back to the CP3 model in 2021 and on. Avoid those year model diesels if you ultimately go that way."
WHY avoid those two years? RAM is replacing every single injection pump at ZERO cost on those two years.
Why? Because you have to take a number and get in (a long) line….
Unless, of course, if it cuts loose and plays shrapnel bomb on your engine. In which case you get bumped up to the end of the already broken trucks backorder line!
