agesilaus's avatar
agesilaus
Explorer III
Feb 28, 2022
Dually life? What about Ford 6.2L
As my search for a replacement for my totaled F350 I see a number of RAM diesel 3500 duallys (2017) showing up at a very good price. One in particular a Laredo at 40K with all sorts of options.
I've never driven a drw before and it seems overkill for our 9K Trailer.
Are they that much harder to drive and park? What about mileage? Better than a gasser anyway I assume. We'll look at it Tuesday probably.
Lots of gas 6.2L around at a good price. And thoughts on that engine from owners?
  • jdc1 wrote:
    All I can say about a dually is a friend took one for a test drive. A few blocks away at a Home Depot, he attempted to park. Three minutes later he parked...right back at the dealer lot. He bought a single wheel 3500 instead. If you don't need the extra payload capacity, why get the extra two wheels? That's just more money to shell out when you need tires. Just to let you know, once you own a diesel truck, you'll never go back to gas.
    Well I guess he didn't think to park out and take two stalls. Walking is good. Or park one wheel up on the curb.
    Two tires over 60k sure doesn't break the bank! especially when those tires are less $ than the 18's and 20's that come on the trucks these days.
  • Ivylog wrote:
    Recently bought a new F350 4X4 single tire with 6.2 for $43K. No it doesn’t have the power of a diesel but also not $80K. Use it mainly to pull a heavy trailer(15,000+ lbs) locally so only getting 5-6 mpg and the 10 speed takes a little getting used to but it does the job.
    Gets down to how many miles/year you’ll be towing and you do not need a dually.
    And if you got a diesel F350 DRW in the same trim level as your gas DRW it would only be $10K more not $37K more.
    Geesh.
  • Interested in your thoughts on what constitutes good prices on them 2017 Cummins Dooleys.
    Dooley owners will tell you how it's not a big deal, hips aren't wider than the mirrors, blah blah blah. If you don't go to the city much, fine, prolly not much an issue.
    Being totally overkill for your situation (as I perceive it), if it's basically a tow rig, I'd go for it if it was a "deal". If it's a daily more than a tow pig, I wouldn't downplay the inconvenience.
    If you use car washes, you won't be able to anymore. If you like your Starclucks drive thru, you'll have to get your feet moving. For the last 2 years up here, if you want fast food, hope it fits in the drive thru, because all the fast food joints are closed to go indoors and order. But now that Covid is almost over here, lol, maybe you'll be able to buy a Big Mac and Fries if you own a dually.
    Narrow driveway, no beuno.
    But this is totally subjective and I'd hope you don't decide on a dually or not based on random folks telling you their opinion.
    6.2 Ford gassers are pretty bulletproof. First several years, 250s and 350s got the same 6R140 trans as the diesels. Bulletproof trans as well and great shift programming.
    At some point (2017 maybe) the F250s got a lighter duty version of the trans. Not that I've heard of problems, but just a FYI.
    I had a 2012 and 2015 F250, 6.2, 3.73s. They would pull 14klb flatbeds with relative ease at low altitude, never ran em at high altitude. Typical gasser fuel mileage, but smooth and quiet, even when locked in a lower gear and running 4-5k rpms.
    They pull better than a 6.0 GM gasser and probably not as good as a 6.4 8 speed Ram or certainly the 7.3 Ford.
  • jdc1's avatar
    jdc1
    Explorer II
  • From what I've read the 6.2 is a solid reliable engine, but not tons of power. Fords new 7.3 gas seems to be a beast for a gas motor. It came out in 2020, so there are a few used ones out there. Unfortunately they are more than you can order a new one for.
    Sorry your old truck got totaled, it's a rough time to need to buy a truck.
  • Ivylog's avatar
    Ivylog
    Explorer III
44,044 PostsLatest Activity: Jul 29, 2025
