Yea they were made by happijac , when I picked up my Outfitter they had them there on the camper for me because I knew there was an issue with my flares on my SRW Dodge, that was in 04
I looked at the happijac store online and didnt see them either
On the northstar I had before that I made some out of 2" box I drilled acsess holes on two sides to get to the nuts with a socket
I dont remember ,are the bolts on the flipouts embeded - non removable also ?Seems like they where countersunk allen heads. If not space it out there .I know they are not removable on the jacks, but on the 3 campers I had happijac`s on the bolts stuck out farther than the head of the nuts .I see yours dont in the pictures, Outfitter used to put two links of chain under one of the bottom jack bolts and use it as front hold downs
If all else fails call happijac and may be they still have some
Like I said though adding 2 full inches to the swing outs is probably going to give you a mild heart attack when you see it on the ground like that
Could you split the flipouts and weld a plate over it and extend them out just as much as you can get away with, might sound extreem but better than putting that much leveraged force on your camper bracket attachment?
